[postgis-users] Compiling PostGIS SVN on Gentoo amd64
Paragon Corporation
lr at pcorp.us
Tue May 12 13:32:01 PDT 2009
Stan,
I recall having similar problems. Not exactly these ones but to do with the
pgis_geometry_accum. I think in my case it was just I forgot to sh
autogen.sh after synching with the latest svn.
So I guess just verify you did that too if you are pulling directly from
subversion.
Hope that helps,
Regina
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Mark
Cave-Ayland
Sent: Tuesday, May 12, 2009 9:57 AM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] Compiling PostGIS SVN on Gentoo amd64
Sufficool, Stanley wrote:
> I'm having issues compiling the recent PostGIS SVN with PostgreSQL 8.4.
> Any clues would be appreciated.
> *postgis configure:*
> ./configure --prefix=/usr --build=amd64
> *make:*
> lwgeom_accum.c: In function 'pgis_geometry_accum_transfn':
> lwgeom_accum.c:106: error: 'T_WindowAggState' undeclared (first use in
> this function)
> lwgeom_accum.c:106: error: (Each undeclared identifier is reported
> only once
> lwgeom_accum.c:106: error: for each function it appears in.)
> lwgeom_accum.c:107: error: 'WindowAggState' undeclared (first use in
> this function)
> lwgeom_accum.c:107: error: expected expression before ')' token
> lwgeom_accum.c: In function 'pgis_accum_finalfn':
> lwgeom_accum.c:167: error: too many arguments to function
> 'makeMdArrayResult'
Hi Stanley,
I did a fresh checkout of both PostGIS SVN and PostgreSQL 8.4 which works
for me without any issues. One thing to bear in mind is that PostGIS SVN
takes all of its installation paths from your PostgreSQL installation
automatically, and so may be confused by the --prefix parameter (see
http://postgis.refractions.net/documentation/manual-svn/ch02.html for the
new configure parameters).
If that doesn't help then you'll need to post the output of configure for us
to look at.
ATB,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
__________ Information from ESET NOD32 Antivirus, version of virus signature
database 4067 (20090512) __________
The message was checked by ESET NOD32 Antivirus.
http://www.eset.com
