[postgis-users] (no subject)
rahul.pachaghare at tcs.com
Tue May 12 23:26:45 PDT 2009
I am new to this and I am trying to install PostGIS -1.3.6.I have followed
the instructions upto createlang plpgsql..But for
Now load the PostGIS object and function definitions into your database by
loading the lwpostgis.sql definitions file.
# psql -d [yourdatabase] -f lwpostgis.
I am getting a huge errors.The errors are as:
psql:lwpostgis.sql:3295: ERROR: current transaction is aborted, commands
ignored until end of transaction block
psql:lwpostgis.sql:3334: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3347: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3354: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3359: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3365: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3374: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3378: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3388: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3392: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3397: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3401: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3405: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3409: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3413: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3417: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3469: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3479: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3485: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3491: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3497: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3503: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3509: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3515: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3521: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3527: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3533: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3539: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3545: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3551: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3557: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3564: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3570: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3576: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3582: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3588: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3594: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3600: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3606: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3612: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3618: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3624: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3630: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3636: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3642: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3648: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3651: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3652: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3653: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3654: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3655: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3656: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3657: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3658: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3659: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3660: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3661: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3662: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3663: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3674: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3680: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3687: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3693: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3700: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3706: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3713: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3719: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3726: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3732: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3738: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3744: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3754: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3760: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3766: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3772: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3778: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3784: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3790: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3796: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3802: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3808: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3818: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3824: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3830: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3836: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3842: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3848: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3854: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3860: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3867: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3873: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3879: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3885: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3891: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3897: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3903: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3909: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3915: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3921: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3927: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3934: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3941: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3947: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3953: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3961: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3969: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3975: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3981: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3987: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3993: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:3999: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4005: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4011: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4017: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4024: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4030: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4036: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4042: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4048: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4055: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4060: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4066: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4073: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4079: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4085: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4092: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4098: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4104: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4111: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4117: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4123: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4129: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4136: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4142: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4149: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4155: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4161: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4168: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4174: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4181: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4187: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4193: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4199: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4205: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4211: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4217: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4223: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4229: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4235: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4241: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4247: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4253: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4263: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4269: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4275: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4281: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4287: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4293: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4302: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4309: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4315: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4322: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4328: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4335: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4342: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4352: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4359: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4365: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4372: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4379: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4385: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4392: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4399: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4409: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4415: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4421: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4427: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4433: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4439: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4445: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4456: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4462: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4468: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4474: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4480: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4486: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4492: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4498: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4504: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4510: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4516: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4522: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4528: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4534: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4540: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4546: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4552: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4579: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4585: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4591: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4597: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4603: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4609: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4615: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4621: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4627: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4633: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4639: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4645: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4651: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4657: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4663: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4669: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4675: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4681: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4687: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4693: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4699: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4705: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4711: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4717: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4723: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4729: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4735: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4741: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4747: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4753: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4759: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4765: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4771: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4777: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4782: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4787: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4792: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4797: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4807: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4817: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4827: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4838: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4848: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4858: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4868: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4878: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4884: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4890: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4900: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4910: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4920: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4930: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4936: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4942: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4948: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4954: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4965: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4976: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4986: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:4996: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:5002: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:5008: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:5014: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:5020: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:5030: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:5040: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:5050: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:5060: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:5066: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:5072: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:5078: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:5084: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:5090: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:5100: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:5110: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:5120: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:5130: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:5136: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:5142: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:5148: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:5154: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:5165: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:5176: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:5187: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:5198: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:5204: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:5210: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:5216: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:5222: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:5232: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:5242: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:5252: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:5262: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:5272: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:5282: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:5292: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:5302: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:5312: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:5322: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:5332: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:5342: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:5352: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:5362: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:5372: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:5382: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:5392: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:5402: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:5412: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:5422: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:5432: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:5442: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:5452: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:5462: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:5472: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:5482: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:5492: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:5502: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:5512: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:5522: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:5532: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:5542: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:5552: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:5562: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:5572: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:5582: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:5592: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:5602: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:5612: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:5622: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:5632: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:5642: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:5652: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:5662: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:5673: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:5684: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:5695: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:5706: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:5749: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:5778: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:5814: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:5838: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:5882: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:5933: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:5940: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:5947: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:5954: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:5987: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:6020: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:6027: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:6032: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:6037: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:6096: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:6114: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:6159: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:6218: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:6238: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:6295: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:6318: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:6332: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:6346: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:6360: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:6366: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:6372: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:6410: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:6459: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:6482: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:6488: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:6512: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:6523: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:6528: ERROR: current transaction is aborted, commands
psql:lwpostgis.sql:6533: ERROR: current transaction is aborted, commands
ROLLBACK
Above is not the complete list of errors.....Anyone got any idea?
Thank You in advance.
Regards,
Rahul Pachaghare
Member,TEG Open Source
Tata Consultancy Services
Mailto: rahul.pachaghare at tcs.com
Website: http://www.tcs.com
____________________________________________
Experience certainty. IT Services
Business Solutions
Outsourcing
Notice: The information contained in this e-mail
message and/or attachments to it may contain
confidential or privileged information. If you are
not the intended recipient, any dissemination, use,
review, distribution, printing or copying of the
information contained in this e-mail message
and/or attachments to it are strictly prohibited. If
you have received this communication in error,
please notify us by reply e-mail or telephone and
immediately and permanently delete the message
and any attachments. Thank you
