[postgis-users] spatial_ref_sys
Genís Pujol Hamelink
gpujol at lrt.cat
Wed May 13 07:44:25 PDT 2009
Hello list,
In the postgis datatable there is an entry for the ED50 / 30N but not for
ED50 / 31N and I need to add this into the db:
PROJCS["ED_1950_UTM_Zone_31N",
GEOGCS["GCS_European_1950",
DATUM["European_Datum_1950",
SPHEROID["International_1924",6378388.0,297.0]],
PRIMEM["Greenwich",0.0],
UNIT["Degree",0.0174532925199433]],
PROJECTION["Transverse_Mercator"],
PARAMETER["False_Easting",500000.0],
PARAMETER["False_Northing",0.0],
PARAMETER["Central_Meridian",3.0],
PARAMETER["Scale_Factor",0.9996],
PARAMETER["Latitude_Of_Origin",0.0],
UNIT["Meter",1.0]]
I miss the info regarding the EPSG or the auth codes and I'm not sure if I
can add it as a custom dataset and make up those codes without braking
anything...
How can I add this into the db without braking anything? sorry I'm a noob at
gis... :)
regards,
Genis
Genís
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090513/889607d6/attachment.html>
