[postgis-users] Viewshed Isovist
Matthew Snape
SnapeM at rpsgroup.com
Fri May 15 06:03:45 PDT 2009
Do you have to maintain the data in vector? Grass has a viewshed tool
for raster inputs, which I believe ships with QGIS.
http://grass.itc.it/grass62/manuals/html62_user/r.los.html
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
diplonics
Sent: 14 May 2009 19:10
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] Viewshed Isovist
Hi All,
Just wondering if this can be done in PostGIS and if not does anyone
know of the simplest method to get it done. I have 2 PostGIS polygon
geometry tables and I want to basically do is an isovist/viewshed/line
of
sigth operation. I know an intersection operation can isolate where the
polys are spatially equal but what I want is some sort of set complement
operation where it will also remove all polygon sections without direct
line
of sight.
Image 1 is a sample of my two data sets. The purple polys are building
outlines while the yellow poly is an unobstructed viewshed from a line.
http://www.nabble.com/file/p23546020/ViewShed01.png
Image 2 is a sample of the desired result. Using a PostGIS intersection
operation I can isolate the green sections, but I want to return a
geometry
that is the yellow section with the green and red sections removed.
http://www.nabble.com/file/p23546020/ViewShed02.png
Any advice on this problem, or links to help, would be greatly
appreciated.
Thanks
View this message in context:
http://www.nabble.com/Viewshed-Isovist-tp23546020p23546020.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
This e-mail message and any attached file is the property of the sender and is sent in confidence to the addressee only. The contents are not to be disclosed to anyone other than
the addressee. Unauthorised recipients are requested to preserve this confidentiality and to advise the sender immediately of any error in transmission. If you experience difficulty
with opening any attachments to this message, or with sending a reply by email, please telephone on + 44-(0)1235 438151 or fax on + 44-(0)1235 438188.
Any advice contained in this e-mail or any accompanying file attached hereto is for information purposes only. RPS do not take any responsibility for differences between the original
and the transmission copy or any amendments made thereafter. If the addressee requires RPS to be responsible for the contents of this e-mail, RPS will be pleased to issue a signed
hard copy of the document upon request.
RPS Planning and Development Limited, company number: 02947164 (England). Registered office: Centurion Court, 85 Milton Park Abingdon Oxfordshire OX14 4RY.
RPS Group Plc web link: <http://www.rpsgroup.com>
