[postgis-users] osm2pgsql exports no data into database
Mehmet
m.sirin07 at googlemail.com
Sat May 16 04:35:00 PDT 2009
Hi
i was trying to convert from osm to sql or to a postgis database via
osm2pgsql. But after typing C:\osm2pgsql> osm2pgsql -U postgres -d routing
data.osm nothing is written to the database.
The prompt is :
osm2pgsql SVN version 0.55-20081113 $Rev: 10464 $
Using projection SRS 900913 (Spherical Mercator)
Setting up table: planet_osm_point
Setting up table: planet_osm_line
Setting up table: planet_osm_polygon
Setting up table: planet_osm_roads
Mid: Ram, scale=100
Reading in file: jo.osm
StartElement: Unknown element name: bounds
EndElement: Unknown element name: bounds
Processing: Node(12k) Way(1k) Relation(0k)
Node stats: total(12644), max(393897777)
Way stats: total(1858), max(34338222)
Relation stats: total(7), max(93919)
Writing way(0k)
0k?? Anyone knows whats going on here?
I'm using PostgreSQL 8.3 and PostGIS 1.3.5
kind regards
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090516/ec368396/attachment.html>
