[postgis-users] installation issue - compiling proj4
Paul Ramsey
pramsey at opengeo.org
Fri May 15 10:14:42 PDT 2009
On Fri, May 15, 2009 at 10:04 AM, Paul McCullough
<paul.mccullough at sfgov.org> wrote:
> My question include
> - how can I tell if proj4 is installed correctly?
run the 'proj' command and see it convert something for you. probably
it's fine. the nad2nad missing issue will be a problem if you do datum
shifts in your work. getting datum support is trickier than it should
be. you have to download the separate proj-datumgrid-1.4.zip file and
unzip it into the ./nad directory in the proj4 source. (yeah) then
recompile and reinstall
> - should I be worried all the errors I encountered while doing the yum
> installs?
perhaps, though you got things to work in the end. generally package
installs should be silent and deadly and noise indicates something
awry. not a postgis/proj issue though.
> - should I not be using the 64bit OS?
64bit should work fine in this day-and-age, and compiling from scratch
is the best way to ensure your software actually is running 64bit.
Paul
> Thanks
> Paul
> View this message in context: http://www.nabble.com/installation-issue---compiling-proj4-tp23563815p23563815.html
> Sent from the PostGIS - User mailing list archive at Nabble.com.
> postgis-users mailing list
