[postgis-users] Problems compiling PostGIS on Solaris 2.10/SparcV9
Alexander Von Luenen
Alex.von-Luenen at port.ac.uk
Tue May 19 10:04:45 PDT 2009
Indeed. One can really google too much, can't you? ;-)
Using '--with-pgsql' does the trick. Thanks a lot!
Alex
Dr Alexander von Luenen
Senior Research Associate
Great Britain Historical GIS
Dept. of Geography
University of Portsmouth
Buckingham Building, Lion Terrace
Portsmouth, PO1 3HE, UK
tel: +44-(0)23-9284-2500
fax: +44-(0)23-9284-2512
>>> Mark Cave-Ayland <mark.cave-ayland at siriusit.co.uk> 19/05/2009 17:46 >>>
Alexander Von Luenen wrote:
> Hi,
> I am trying to compile PostGIS on a SUN T5440 running Solaris 2.10, using gcc3.4.3. I have PostgreSQL 8.3.1
> installed from the CSW repository, which has both 32bit and 64bit
versions installed. Although the pg_config
> installed in /opt/csw/postgresql/bin is a 32bit binary (as I could
check with 'file'), all paths etc. it returns
> are to the 64bit version of PostgreSQL. As I have compiled all
libraries (GEOS, PROJ4, etc) as 32bit, this results
> in a linker error when compiling PostGIS, since it attempts to link
the 32bit libs to the 64bit PostgreSQL libs.
> Using '-m32' as CPPFLAGS/CXXFLAGS didn't help. There is also a
pg_config32 in the same directory as pg_config.
> How can I force configure to use this one? '--with-pgconfig' didn't
work. The only solution I could think of
> is deleting/renaming pg_config, and setting a softlink to
pg_config32. Any suggestions anybody?
> Cheers,
> Alex
Hi Alex,
It looks as if you've picked up the new SVN documentation instead - the
options for PostGIS 1.4 have been changed to make them easier to
understand. The option you need to pass to configure for the 1.3 series
is --with-pgsql=/path/to/pg_config.
HTH,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
