re[postgis-users] solved - more centos install troubles
Paul McCullough
paul.mccullough at sfgov.org
Wed May 20 16:47:15 PDT 2009
All,
Thanks to your help, I was able to get everything installed.
One of the key steps was to use pgsqlrpms rather than centos:
http://yum.pgsqlrpms.org/howtoyum.php
This was also a helpful page:
http://www.postgresonline.com/journal/index.php?/archives/45-An-Almost-Idiots-Guide-to-PostgreSQL-YUM.html
Finally, I include my (internal) wiki notes.
Sorry about the missing formatting.
Cheers!
Paul
Introduction
Do this slowly and carefully, and if your lucky, you won't get hurt.
keywords
Fedora 8
Fedora 9
centos
proj.4
geos
postgis
postgresql
[edit] one - install proj4 (projection library)
>From http://trac.osgeo.org/proj/, download and install the the PROJ4
projection library source.
$ cd /tmp
$ wget http://download.osgeo.org/proj/proj-4.6.1.tar.gz
$ tar xvfz proj-4.6.1.tar.gz
$ cd proj-4.6.0
$ ./configure
If you are on a fresh system, you may see a number errors such as
* "C preprocessor "/lib/cpp" fails sanity check"
* no compiler found
* etc
If so, you need to fiddle a bit.
Here is some of the buckshot I used; sometimes reapeating yum installs.
I'm just a hacker; you are welcome to do correctly and edit this doc.
> yum install gcc
> yum groupinstall "Development Libraries"
> yum install glibc-headers glibc glibc-commonglibc-devel
> yum update glibc glibc-common glibc-headers glibc-devel
then proceed...
$ make
$ su
$ make install
$ exit
Odd as though it may sound, "make" may not have been installed.
$ yum install make
Lather, rinse, repeat.
You should eventually see no errors and no dependency check failures.
[edit] two - install GEOS (C++ port of the Java Topology Suite)
$ bunzip2 geos-3.0.0.tar.bz2
$ tar xvf geos-3.0.0.tar
$ cd geos-3.0.0
$ ./configure
$ make
$ su
$ make install
$ exit
ON centos, when I issued the make command I saw this:
../../../libtool: line 1223: g++: command not found
The googles suggested
yum install gcc-c++
which worked first time.
If the output from "make install" included the following
Libraries have been installed in:
/usr/local/lib
If you ever happen to want to link against installed libraries
in a given directory, LIBDIR, you must either use libtool, and
specify the full pathname of the library, or use the `-LLIBDIR'
flag during linking and do at least one of the following:
- add LIBDIR to the `LD_LIBRARY_PATH' environment variable
during execution
- add LIBDIR to the `LD_RUN_PATH' environment variable
during linking
- use the `-Wl,--rpath -Wl,LIBDIR' linker flag
- have your system administrator add LIBDIR to `/etc/ld.so.conf'
See any operating system documentation about shared libraries for
more information, such as the ld(1) and ld.so(8) manual pages.
you need to do this:
echo '/usr/local/lib' >> /etc/ld.so.conf.d/local-lib.conf
ldconfig
[edit] three - install PostGIS
In order to build postGIS you need some artifacts from the postgresQL
development package. This is not as straight forward as it should be.
I encourage you to take a few minutes to read this through. First, your
"disto repository" is not likely to be up to date with respect to postgresql
packages. In other words, if you blindly type "yum install
postgresql-devel", you may have trouble getting everything installed
properly. I've seen errors regarding missing libraries and the like. To
avoid the fuss, when you are installing postgresql packages, use the
postgresql repositories instead of your ditsro repsository.
Here is how you do that. You should read this from top to bottom.
Also read this; you can safley skip sections on this page.
Did you do your reading?
OK, now we build postGIS.
$ yum install postgresql-devel
$ tar xvfz postgis-1.3.1.tar.gz
$ cd postgis-1.3.1
$ ./configure --with-pgsql=/usr/bin/pg_config
--with-geos=/usr/local/bin/geos-config --with-proj=/usr/local
$ make
$ su
$ make install
$ exit
Errors I've seen: error
configure: error: Can't find 'flex'
solution
yum install flex
[edit] four - make a database
$ su postgres
$ cd
$ createdb sfmaps
$ createlang plpgsql sfmaps
$ psql -f /usr/share/lwpostgis.sql -d sfmaps (error: could not load library)
$ psql -f /usr/share/spatial_ref_sys.sql -d sfmaps
$ psql sfmaps
if you encounter this error:
libgeos_c.so.1: cannot open shared object file: No such file or
directory<br>
do this
Add /usr/local/lib to the dynamic linker run-time bindings
ldconfig
[edit] five - make a postgis_template (optional)
This page shows how to create and use a db template:
http://geospatial.nomad-labs.com/2006/12/24/postgis-template-database/
View this message in context: http://www.nabble.com/more-centos-install-troubles-tp23626022p23645586.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
