[postgis-users] upgrade a database from postgis 1.3 -> 1.4
Dylan Beaudette debeaudette at ucdavis.edu
Fri May 29 12:12:51 PDT 2009
After working through the issues related to upgrading a postgis-enabled DB up
through 1.3.3, I am now stuck as to how I should upgrade to 1.4. All of the
functions are replaced when I run postgis.sql, however, none of the
AGGREGATES are updated. Is there a clean way to do this? Or will I need to
manually remove all of the AGGREGATES, and then re-run postgis.sql?
Thanks!
Dylan
Dylan Beaudette
Soil Resource Laboratory
http://casoilresource.lawr.ucdavis.edu/
University of California at Davis
530.754.7341
