[postgis-users] Unable to build WKT Raster
Paragon Corporation lr at pcorp.us
Sun Nov 1 16:59:38 PST 2009
Mateusz,
We should probably update the docs here accordingly
http://trac.osgeo.org/postgis/wiki/WKTRaster/Documentation01
This user doc way at the bottom says it works with 1.3.5 or higher and even
points at the 1.3 docs for compilation.
Thanks,
Regina
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Mateusz
Loskot
Sent: Sunday, November 01, 2009 6:17 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] Unable to build WKT Raster
Gilles Bassière wrote:
> Hi list,
> I'd like to try WKT Raster but I have some troubles during install.
> My first attempt was to build WKT Raster aginst PostGIS 1.3.5 source
> code but the configure script fails because the liblwgeom/ directory
> does not exist prior to PostGIS 1.4.0. I tried to create a symlink and
> even to rename the directory lwgeom/ to liblwgeom/ but in both case,
> WKT Raster don't build:
The WKT Raster README file available from
http://trac.osgeo.org/postgis/browser/spike/wktraster/README
says
"latest 1.3.5 release won't work"
> Full configure output: http://pastebin.org/49983 Full build output:
> http://pastebin.org/49982 pg_config output: http://pastebin.org/49984
It will not work. Please, use PostGIS 1.4.0 or recent source code from trunk
in SVN repository
> I also tried to build and install PostGIS 1.4.0 but I can't find a way
> to do so within my home directory since the --prefix option is now
> ignored (bug #160). Of course, I could compile a full PostgreSQL in my
> home directory but there might be an easier solution, is there?
If you want to build PostGIS, you need to compile and install PostGIS only,
no need to compile PostgreSQL.
Best regards,
Mateusz Loskot, http://mateusz.loskot.net Charter Member of OSGeo,
http://osgeo.org _______________________________________________
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
