[postgis-users] SOLVED: Combining / agglomerating / clustering numbers of adjacent polygons
Paragon Corporation
lr at pcorp.us
Thu Nov 5 00:31:13 PST 2009
Derek,
FWIW -- this is a bit faster and shorter to write than your last step. You
probably won't notice the difference until you start dealing with huge
geometry collections.
--REVISED LAST STEP
create table
agglom_areas
as
SELECT (ST_Dump(the_geom)).geom As split_geom
FROM temp_f;
---YOUR LAST STEP--
create table
agglom_areas
as
select
st_GeometryN
the_geom,
generate_series(1,st_NumGeometries(the_geom))
) as split_geom
from
temp_f;
Leo
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Derek
Jones
Sent: Wednesday, November 04, 2009 10:26 PM
Cc: PostGIS Users Discussion
Subject: [postgis-users] SOLVED: Combining / agglomerating / clustering
Dear all,
I solved the problem with just a handful of lines of SQL in the end... :-P
Kinda roundabout thinking but it worked. Here's the solution:
grid_squares contains my reduced grid set from the complete grid overlay
from a previous select - it's the density table. I also previously removed
singletons from it with a check for any grid entries that had 0 touching
entities.
# Break out the multipolygon grids into polygons
create table
temp_e
as
select
st_GeometryN
the_geom,
) as split_geom
from
grid_squares;
# Break out the polygons into linestrings and agglomerate into areas #
Becomes one big area as a multipolygon so ...
create table
temp_f
as
select
st_buildarea
st_collect
st_ExteriorRing(split_geom)
) as the_geom
from
temp_e;
# ... afterwards, break out into polygons again # each of which is the
clustered set of # polygons comprising the outer boundary agglomeration # of
the original grid areas.
create table
agglom_areas
as
select
st_GeometryN
the_geom,
) as split_geom
from
temp_f;
I can probably with a little work reduce the steps but I don't have a need
to at this point.
This does exactly what I wanted - hope it's useful perhaps to others in the
same jam. Appreciate the help given in any event.
Now I can use the generated areas to get me some centroids and then both
intersect and then cluster the "other" data set I have which is 10s of 1000s
of points and different to this one but related to it.
Thank you again. Always useful to bounce these kinds of things around...
Kind regards
Derek Jones
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
