[postgis-users] SOLVED: Combining / agglomerating / clustering numbers of adjacent polygons
Derek Jones scunacc at yahoo.com
Thu Nov 5 04:35:24 PST 2009
Dear Leo
Hey thanks!
Since these and other steps can run for several tens of minutes or even
hours because of the data densities, I didn't notice because I left them
each cooking and did something else instead, but I appreciate any
improvements here because I may well be running the same kind of query
elsewhere also.
Occam's Razor and all that ;-)
Kind regards
Derek.
Paragon Corporation wrote:
> Derek,
> FWIW -- this is a bit faster and shorter to write than your last step.  You
> probably won't notice the difference until you start dealing with huge
> geometry collections.
> --REVISED LAST STEP
> create table
>    agglom_areas
> as
>    SELECT (ST_Dump(the_geom)).geom As split_geom
> 	FROM temp_f;
> ---YOUR LAST STEP--
> create table
>    agglom_areas
> as
>    select
>      st_GeometryN
>        the_geom,
>        generate_series(1,st_NumGeometries(the_geom))
>      ) as split_geom
>    from
>      temp_f;
> Leo
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Derek
> Jones
> Sent: Wednesday, November 04, 2009 10:26 PM
> Cc: PostGIS Users Discussion
> Subject: [postgis-users] SOLVED: Combining / agglomerating / clustering
> Dear all,
> I solved the problem with just a handful of lines of SQL in the end... :-P
> Kinda roundabout thinking but it worked. Here's the solution:
> grid_squares contains my reduced grid set from the complete grid overlay
> from a previous select - it's the density table. I also previously removed
> singletons from it with a check for any grid entries that had 0 touching
> entities.
> # Break out the multipolygon grids into polygons
> create table
>    temp_e
> as
>    select
>      st_GeometryN
>        the_geom,
>      ) as split_geom
>    from
>      grid_squares;
> # Break out the polygons into linestrings and agglomerate into areas #
> Becomes one big area as a multipolygon so ...
> create table
>    temp_f
> as
>    select
>      st_buildarea
>        st_collect
>          st_ExteriorRing(split_geom)
>      ) as the_geom
>    from
>      temp_e;
> # ... afterwards, break out into polygons again # each of which is the
> clustered set of # polygons comprising the outer boundary agglomeration # of
> the original grid areas.
> create table
>    agglom_areas
> as
>    select
>      st_GeometryN
>        the_geom,
>      ) as split_geom
>    from
>      temp_f;
> I can probably with a little work reduce the steps but I don't have a need
> to at this point.
> This does exactly what I wanted - hope it's useful perhaps to others in the
> same jam. Appreciate the help given in any event.
> Now I can use the generated areas to get me some centroids and then both
> intersect and then cluster the "other" data set I have which is 10s of 1000s
> of points and different to this one but related to it.
> Thank you again. Always useful to bounce these kinds of things around...
> Kind regards
> Derek Jones
> postgis-users mailing list
