[postgis-users] Postgis for dummies
Fernando Tong nandorov at gmail.com
Fri Nov 6 11:16:34 PST 2009
it works,  thank you very much. However, i wonder if this is the best way (:
On Fri, Nov 6, 2009 at 1:26 PM, Moen, Paul T. <pmoen at nd.gov> wrote:
> SELECT DISTINCT ST_X(ST_POINTN(foo.lines,foo.index)) AS
> x,ST_Y(ST_POINTN(foo.lines,foo.index)) AS y FROM
>  (select thelines.lines,generate_series(1,thelines.n) AS index FROM
> (select polys.geo AS lines, ST_NUMPOINTS(polys.geo) AS n FROM
>  (SELECT ST_BOUNDARY((ST_DUMP(the_geom)).geom) AS geo FROM "YOURTABLE"
> WHERE YOURQUERY) AS polys)
> AS thelines)
>  AS foo;
> should work for multipolygons and polygons.although there may be an easier
> way.
> Paul Moen
> On Nov 6, 2009, at 12:03 PM, Fernando Tong wrote:
> I have a dummy question:
> i have a POLYGON, how can i get all the polygon's coordinates with a SELECT
> query?
> something like:
> select unknown_functions(polygon) from mytable
> output:
> 1 POINT(1 2)
> 2 POINT(2 2)
> 3 POINT(3 2)
> or much better if i get
>     X    Y
> 1  1     2
> 2  2     2
> 3  3     2
> Thanks a lot.
> On Fri, Nov 6, 2009 at 9:19 AM, David Fawcett <david.fawcett at gmail.com>wrote:
>> I think that another good way to approach it is to have a task/problem
>> that you want to solve using PostGIS (whether real or made up).  Learn
>> what you need to about PostGIS to solve that problem and branch out
>> from there.
>> David.
>> On Fri, Nov 6, 2009 at 12:04 AM, Paragon Corporation <lr at pcorp.us> wrote:
>> > You can also look at some of these - might be helpful
>> http://www.bostongis.com/PrinterFriendly.aspx?content_name=postgis_tut01
>> > http://workshops.opengeo.org/stack-intro/
>> > This one is a bit dated but probably still useful
>> > http://2007.foss4g.org/workshops/W-04/
>> > Leo
>> > ________________________________
>> > From: postgis-users-bounces at postgis.refractions.net
>> > [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Bob
>> and
>> > Deb
>> > Sent: Thursday, November 05, 2009 11:51 PM
>> > To: PostGIS Users Discussion
>> > Subject: Re: [postgis-users] Postgis for dummies
>> > How about the book, "PostGIS in Action" ?   There is even a free chapter
>> > that might give you enough info to get started.  There is also the Wiki.
>> > -Bob
>> > On Thu, Nov 5, 2009 at 6:34 PM, Jeff Matthews <info at sovereignstates.net
>> > wrote:
>> >> Need link to tutorial at the “dummy” level.
>> >> I know a bit about kml, but that’s it.  In looking at postgis, I now
>> see,
>> >> in the instructions, things like, “To spatially-enable a jump-oriented
>> >> static sql line pointer,….”   That’s just wayyyy over me.  Where do I
>> go as
>> >> I newbie in gis to become a pro like you all?
>> >> Thanks.
>> >> _______________________________________________
>> >> postgis-users mailing list
>> >> postgis-users at postgis.refractions.net
>> >> http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20091106/1f408a7f/attachment.html>
