[postgis-users] Postgis for dummies
Kevin Neufeld
kneufeld at refractions.net
Fri Nov 6 21:04:10 PST 2009
The best way? Unfortunately, at this point in time, I'm afraid so.
We've had this on our wish list for some time now
(http://trac.osgeo.org/postgis/ticket/76). If you want, you can import
a plpgsql implementation of this until it's implemented in C
(http://trac.osgeo.org/postgis/attachment/ticket/76/my_st_dump_points.2.sql).
Usage would be something like:
SELECT ST_AsText( (ST_DumpPoints( poly )).geom )
FROM (
SELECT 'POLYGON((0 0, 1 1, 1 0, 0 0))'::geometry AS poly
) AS foo;
st_astext
POINT(0 0)
POINT(1 1)
POINT(1 0)
POINT(0 0)
(4 rows)
Cheers,
Kevin
Fernando Tong wrote:
> it works, thank you very much. However, i wonder if this is the best
> way (:
> On Fri, Nov 6, 2009 at 1:26 PM, Moen, Paul T. <pmoen at nd.gov
> <mailto:pmoen at nd.gov>> wrote:
> SELECT DISTINCT ST_X(ST_POINTN(foo.lines,foo.index)) AS
> x,ST_Y(ST_POINTN(foo.lines,foo.index)) AS y FROM
> (select thelines.lines,generate_series(1,thelines.n) AS index FROM
> (select polys.geo AS lines, ST_NUMPOINTS(polys.geo) AS n FROM
> (SELECT ST_BOUNDARY((ST_DUMP(the_geom)).geom) AS geo FROM
> "YOURTABLE" WHERE YOURQUERY) AS polys)
> AS thelines)
> AS foo;
> should work for multipolygons and polygons.although there may be
> an easier way.
> Paul Moen
> On Nov 6, 2009, at 12:03 PM, Fernando Tong wrote:
>> I have a dummy question:
>> i have a POLYGON, how can i get all the polygon's coordinates
>> with a SELECT query?
>> something like:
>> select unknown_functions(polygon) from mytable
>> output:
>> 1 POINT(1 2)
>> 2 POINT(2 2)
>> 3 POINT(3 2)
>> or much better if i get
>> X Y
>> 1 1 2
>> 2 2 2
>> 3 3 2
>> Thanks a lot.
>> On Fri, Nov 6, 2009 at 9:19 AM, David Fawcett
>> <david.fawcett at gmail.com <mailto:david.fawcett at gmail.com>> wrote:
>> I think that another good way to approach it is to have a
>> task/problem
>> that you want to solve using PostGIS (whether real or made
>> up). Learn
>> what you need to about PostGIS to solve that problem and
>> branch out
>> from there.
>> David.
>> On Fri, Nov 6, 2009 at 12:04 AM, Paragon Corporation
>> <lr at pcorp.us <mailto:lr at pcorp.us>> wrote:
>> > You can also look at some of these - might be helpful
>> http://www.bostongis.com/PrinterFriendly.aspx?content_name=postgis_tut01
>> > http://workshops.opengeo.org/stack-intro/
>> > This one is a bit dated but probably still useful
>> > http://2007.foss4g.org/workshops/W-04/
>> > Leo
>> > ________________________________
>> > From: postgis-users-bounces at postgis.refractions.net
>> <mailto:postgis-users-bounces at postgis.refractions.net>
>> > [mailto:postgis-users-bounces at postgis.refractions.net
>> <mailto:postgis-users-bounces at postgis.refractions.net>] On
>> Behalf Of Bob and
>> > Deb
>> > Sent: Thursday, November 05, 2009 11:51 PM
>> > To: PostGIS Users Discussion
>> > Subject: Re: [postgis-users] Postgis for dummies
>> > How about the book, "PostGIS in Action" ? There is even a
>> free chapter
>> > that might give you enough info to get started. There is
>> also the Wiki.
>> > -Bob
>> > On Thu, Nov 5, 2009 at 6:34 PM, Jeff Matthews
>> <info at sovereignstates.net <mailto:info at sovereignstates.net>>
>> > wrote:
>> >> Need link to tutorial at the “dummy” level.
>> >> I know a bit about kml, but that’s it. In looking at
>> postgis, I now see,
>> >> in the instructions, things like, “To spatially-enable a
>> jump-oriented
>> >> static sql line pointer,….” That’s just wayyyy over me.
>> Where do I go as
>> >> I newbie in gis to become a pro like you all?
>> >> Thanks.
>> >> _______________________________________________
>> >> postgis-users mailing list
>> >> postgis-users at postgis.refractions.net
>> <mailto:postgis-users at postgis.refractions.net>
>> >> http://postgis.refractions.net/mailman/listinfo/postgis-users
