[postgis-users] Postgis for dummies
Jorge Arévalo
jorge.arevalo at gmail.com
Sun Nov 8 07:11:54 PST 2009
On Fri, Nov 6, 2009 at 7:03 PM, Fernando Tong <nandorov at gmail.com> wrote:
> I have a dummy question:
> i have a POLYGON, how can i get all the polygon's coordinates with a SELECT
> query?
> something like:
> select unknown_functions(polygon) from mytable
> output:
> 1 POINT(1 2)
> 2 POINT(2 2)
> 3 POINT(3 2)
> or much better if i get
> X Y
> 1 1 2
> 2 2 2
> 3 3 2
> Thanks a lot.
Maybe a
SELECT ST_AsText(polygon_column) FROM Table
Is enough
Output:
POLYGON( (1 1, 2 2, 3 3) )
> On Fri, Nov 6, 2009 at 9:19 AM, David Fawcett <david.fawcett at gmail.com>
> wrote:
>> I think that another good way to approach it is to have a task/problem
>> that you want to solve using PostGIS (whether real or made up). Learn
>> what you need to about PostGIS to solve that problem and branch out
>> from there.
>> David.
>> On Fri, Nov 6, 2009 at 12:04 AM, Paragon Corporation <lr at pcorp.us> wrote:
>> > You can also look at some of these - might be helpful
>> > http://www.bostongis.com/PrinterFriendly.aspx?content_name=postgis_tut01
>> > http://workshops.opengeo.org/stack-intro/
>> > This one is a bit dated but probably still useful
>> > http://2007.foss4g.org/workshops/W-04/
>> > Leo
>> > ________________________________
>> > From: postgis-users-bounces at postgis.refractions.net
>> > [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Bob
>> > and
>> > Deb
>> > Sent: Thursday, November 05, 2009 11:51 PM
>> > To: PostGIS Users Discussion
>> > Subject: Re: [postgis-users] Postgis for dummies
>> > How about the book, "PostGIS in Action" ? There is even a free chapter
>> > that might give you enough info to get started. There is also the Wiki.
>> > -Bob
>> > On Thu, Nov 5, 2009 at 6:34 PM, Jeff Matthews <info at sovereignstates.net>
>> > wrote:
>> >> Need link to tutorial at the “dummy” level.
>> >> I know a bit about kml, but that’s it. In looking at postgis, I now
>> >> see,
>> >> in the instructions, things like, “To spatially-enable a jump-oriented
>> >> static sql line pointer,….” That’s just wayyyy over me. Where do I
>> >> go as
>> >> I newbie in gis to become a pro like you all?
>> >> Thanks.
>> >> _______________________________________________
>> >> postgis-users mailing list
>> >> postgis-users at postgis.refractions.net
>> >> http://postgis.refractions.net/mailman/listinfo/postgis-users
