[postgis-users] Postgis concurrence question
Nandorov
nandorov at gmail.com
Wed Nov 11 09:05:20 PST 2009
Hello list,
I need some advices of what i'm trying to do. I have a lot of GPS devices
that are sending data(every 10 seconds) to an application (Java). The latter
connects to a Postgis database and inserts the coordinates as POINT datatype
in a table. For testing, i'm using the super user postgres
Everything's working fine after 20 or 15 minutes, the application starts to
throw the following postgis error:
"could not connect to server: connection timed out (0x0000274C/10060)
Is the server running on host "127.0.0.1" and accepting TCP/IP connections
on port 5432"
Some statatements can be executed and some other can not
It could be a problem for using the super user postgres or something related
to max_connections (Currently set at 100) in postgres.conf?
Any ideas? Thanks a lot
Best Regards
Fernando
View this message in context: http://old.nabble.com/Postgis-concurrence-question-tp26304850p26304850.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
