[postgis-users] Postgis concurrence question
Per-Olof Norén
pelle at alma.nu
Wed Nov 11 09:36:59 PST 2009
What postgres and postgis versions are you using?
/p
11 nov 2009 kl. 18.05 skrev Nandorov <nandorov at gmail.com>:
> Hello list,
> I need some advices of what i'm trying to do. I have a lot of GPS
> devices
> that are sending data(every 10 seconds) to an application (Java).
> The latter
> connects to a Postgis database and inserts the coordinates as POINT
> datatype
> in a table. For testing, i'm using the super user postgres
> Everything's working fine after 20 or 15 minutes, the application
> starts to
> throw the following postgis error:
> "could not connect to server: connection timed out (0x0000274C/10060)
> Is the server running on host "127.0.0.1" and accepting TCP/IP
> connections
> on port 5432"
> Some statatements can be executed and some other can not
> It could be a problem for using the super user postgres or something
> related
> to max_connections (Currently set at 100) in postgres.conf?
> Any ideas? Thanks a lot
> Best Regards
> Fernando
> View this message in context: http://old.nabble.com/Postgis-concurrence-question-tp26304850p26304850.html
> Sent from the PostGIS - User mailing list archive at Nabble.com.
> postgis-users mailing list
