[postgis-users] Postgis concurrence question
Fernando Tong
nandorov at gmail.com
Fri Nov 13 06:27:17 PST 2009
Hello Kirill
guess what? I changed my code to use a connection pool, but it was still
failing. So, i started to think the problem was the jdbc driver
(postgresql-8.4-701.jdbc3.jar).I was testing PostgreSQL in windows XP sp3. I
changed to windows 2k3 and everything's working fine now! It seems it was an
issue with Windows XP
I tested it with and without the connection pool. Both ways worked, but i
left the connection pool.
Thanks everyone for your suggestions!
Best regards
Fernando
On Thu, Nov 12, 2009 at 9:49 AM, Fernando Tong <nandorov at gmail.com> wrote:
> Hello Kirill,
> thanks for your suggestions. I'll try to change my application (j2se) to
> make it work with a connection pool.
> Best regards
> Fernando
> On Thu, Nov 12, 2009 at 3:01 AM, Kirill Zinov <kirill.zinov at gmail.com>wrote:
>> Hello Fernando,
>> Looks like something has not been released after you closed connection.
>> This may happen due to java native. I mean garbage collector approach to
>> free the objects. If you'll use a proper connection pool it will take care
>> of the connections re-usage and will speed up your application.
>> When I began my Java coding I tried a low level approach too. Thanks to my
>> friend with strong skills in j2ee, I have realized the benefits from
>> Hibernate and other frameworks faster.
>> Take a look at Hibernate: https://www.hibernate.org/
>> There is a spatial extension: http://www.hibernatespatial.org/
>> I didn't try spatial extension as I wrote before. Even if you will decide
>> not to use Hibernate, I suggest you read a few good articles about
>> connection pooling. It’s a faster way to post/get data because of the
>> connections re-usage. Actually this is a de facto standard in Java world.
>> Kirill,
>> Fernando Tong wrote:
>> Hello Kiril,
>> I'm afraid i'm not using a connection pooling, just an static way to
>> load the drivers
>> public class PgSQLDBConn {
>> static {
>> try {
>> Class.forName("org.postgresql.Driver");
>> } catch (Exception e) {
>> System.out.println(e.getMessage());
>> public Connection getConnection() {
>> Connection connection = null;
>> try {
>> connection =
>> DriverManager.getConnection("jdbc:postgresql://localhost:5432/db_gpstracker","MYUSER","MYPWD");
>> return connection;
>> I call the method getConnection each time i want to connect to the
>> database, execute the statements and then i close the connection (repeat
>> each time i receive some data from the GPS device)
>> Best regards
>> Fernando
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20091113/8953755c/attachment.html>
