[postgis-users] Google Earth/PostGIS integration
Pedro Doria Meunier pdoria at netmadeira.com
Mon Nov 16 04:13:11 PST 2009
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hi Chetna,
Quick answer: yes you can! :)
Through *network link* in Google Earth.
Take the following example (in PHP, use you favourite "poison" ):
1st part - Create the network link to feed to Google Earth
<?php
header("Content-type: application/vnd.google-earth.kml xml kml");
header('Content-Disposition: attachment; filename="g_loc.kml"');
header("Last-Modified: " . gmdate("D, d M Y H:i:s") . " GMT");
header("Cache-Control: cache, must-revalidate");
header("Pragma: public");
echo "<?xml version=\"1.0\" encoding=\"UTF-8\"?>";
echo "<kml xmlns=\"http://earth.google.com/kml/2.1\">";
echo "<Document>";
echo "<name>"._("My Network Link")."</name>";
echo "<NetworkLink>";
echo "<name>"._("My Description")."</name>";
echo "<flyToView>1</flyToView>";
echo "<Link>";
echo
"<href>$mysite/show_my_thing.php?param1=$param1&param2=$param2</href>";
echo "<refreshMode>onInterval</refreshMode>";
echo "<refreshInterval>30</refreshInterval>";
echo "</Link>";
echo "</NetworkLink>";
echo "</Document>";
echo "</kml>";
2nd part - Get your data:
<?php
// connect to  database
include('./include/my_database_connection_script.php');
// start your kml document.
$response = "<?xml version=\"1.0\" encoding=\"UTF-8\"?>";
$response .="<kml xmlns=\"http://earth.google.com/kml/2.1\">";
$response .= "<Document>";
$sql="SELECT my_label, astext(my_geom_field) AS location FROM my_table";
$myresult = pg_exec($connection, $sql);
for ($i=0; $i<pg_numrows($myresult); $i++) {
    $my_label=pg_result($myresult, $i, 0);
    $my_location = pg_result($myresult, $i, 1);
    // extract the geometry
    $geometry = str_replace("POINT(","", pg_result($myresult, $g, 1));
    $geometry = str_replace(")","",$geometry);
    $coordinate = explode(" ",$geometry);
    $lon=$coordinate[0];
    $lat=$coordinate[1];
    // continue filling your document
    $response .= "<Placemark>";
    $response .= "<name>$my_label</name>";
    $response .= "<description><![CDATA[your
description]]></description>";
    $response .= "<Style>";
    $response .=     "<IconStyle>";
    $response .=        "<scale>1</scale>";
    $response .=            "<Icon>";
    $response .=                "<href>$my_site/$my_icon</href>";
    $response .=            "</Icon>";
    $response .=        "</IconStyle";
    $response .=    "<LabelStyle>";
    $response .=        "<color>ff00ffff</color>";
    $response .=        "<scale>0.9</scale>";
    $response .=    "</LabelStyle>";
    $response .= "</Style>";
    $response .= "<Point>";
    $response .=    "<coordinates>$lon,$lat,$altitude</coordinates>";
    $response .= "</Point>";
    $response .= "</Placemark>";
} // result loop
$response .= "</Document>";    // close your document
$response .= "</kml>";               // close your kml
echo $response;                            // feed it to the network link
pg_close($connection);                // don't forget to close the
connection...
This is an example for POINT geometry, of course. Other types are as
easily managed as this.
Your "interface" would be Google Earth :]
You can of course have some "middleware" in a form of a php web page
that allows users to select what they want and then feed it to Google
Earth.
Hope this helps,
BR,
Pedro Doria Meunier
On 11/16/2009 10:49 AM, Chetna Parbhoo wrote:
> I am currently creating a spatial database for a SME. Their project
> data is currently within folders (including all GIS data). I have
> been doing a bit of research when I came across PostgreSQL and
> PostGIS. I plan to use PostGreSQl with PostGIS as a spatial
> extender. I have installed the PostGreSQL and PostGIS as well as
> viewed data stored in the database with QGIS. I need an easy method
> whereby the employees in the company can access data from the
> database on a user friendly interface. Everyone in the company is
> familiar with Google Earth. Is there a way that I can link Google
> Earth with PostGIS to achieve this?
> Many thanks.
> Chetna Parbhoo
> GIS specialist
> chetna at gcs-sa.biz <mailto:chetna at gcs-sa.biz>
> 63 Wessel Road Woodmead
> PO Box 2597 Rivonia 2128
> South Africa
> Tel +27(0)11 803 5726
> Fax +27(0)11 803 5745
> www.gcs-sa.biz <http://www.gcs-sa.biz/>
> postgis-users mailing list
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.9 (GNU/Linux)
Comment: Using GnuPG with Fedora - http://enigmail.mozdev.org/
iEYEARECAAYFAksBQccACgkQ2FH5GXCfxAviywCfZY0R/zgoQogO9kSA8f+NaqZ5
J5wAoIFi+IbdEfVAY336xCXd9d/5ct30
=oXxJ
-----END PGP SIGNATURE-----
