[postgis-users] Google Earth/PostGIS integration
Andreas Neumann
a.neumann at carto.net
Mon Nov 16 04:57:28 PST 2009
Yes, as pedro said you can write your own script (PHP, Perl, Python, Java,
whatever) and use the Postgis AsKML() command. Network Links can embed
db-resources from such a script from a parent KML file.
Another option would be to use Geoserver or gdal/ogr or FME (commercial).
Many GIS also provide KML output, as an example, since you already use
QGIS, there is a KML export plugin from QGIS.
Hope this helps as a starter.
Andreas
On Mon, November 16, 2009 11:49 am, Chetna Parbhoo wrote:
> I am currently creating a spatial database for a SME. Their project data
> is currently within folders (including all GIS data). I have been doing
> a bit of research when I came across PostgreSQL and PostGIS. I plan to
> use PostGreSQl with PostGIS as a spatial extender. I have installed the
> PostGreSQL and PostGIS as well as viewed data stored in the database
> with QGIS. I need an easy method whereby the employees in the company
> can access data from the database on a user friendly interface. Everyone
> in the company is familiar with Google Earth. Is there a way that I can
> link Google Earth with PostGIS to achieve this?
> Many thanks.
> Chetna Parbhoo
> GIS specialist
> chetna at gcs-sa.biz <mailto:chetna at gcs-sa.biz>
> 63 Wessel Road Woodmead
> PO Box 2597 Rivonia 2128
> South Africa
> Tel +27(0)11 803 5726
> Fax +27(0)11 803 5745
> www.gcs-sa.biz <http://www.gcs-sa.biz/>
> postgis-users mailing list
Andreas Neumann
http://www.carto.net/neumann/
http://www.svgopen.org/
