[postgis-users] Best (safest) postGIS version for postgreSQL 8.3.5?
kreshna_iceheart at yahoo.com
Tue Nov 17 01:14:30 PST 2009
Thanks, Mark.
--- On Mon, 11/16/09, Mark Cave-Ayland <mark.cave-ayland at siriusit.co.uk> wrote:
> From: Mark Cave-Ayland <mark.cave-ayland at siriusit.co.uk>
> Subject: Re: [postgis-users] Best (safest) postGIS version for postgreSQL 8.3.5?
> To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
> Date: Monday, November 16, 2009, 10:02 AM
> wrote:
> > What is the safest postGIS version to use with
> postgreSQL 8.3.5? Is it safe to use postgis 1.4.0, for
> example? How about postGIS 1.3.6?
> > Generally, should I go for higher version number, or
> lower?
> > Also, can I use geos 3.1.1 and proj4 4.7.0 with
> postgreSQL 8.3.5? Or should I use lower version number?
> > Many thanks,
> > -Kresh
> Hi Kresh,
> Always go with the latest stable release, which is 1.4
> since it will contain the most number of bug fixes. The
> configure script from 1.4 onwards is fairly good about
> detecting which versions of other libraries can/can't work
> with PostGIS, but if you go with the versions above, you
> should be fine.
> HTH,
> Mark.
> -- Mark Cave-Ayland - Senior Technical Architect
> PostgreSQL - PostGIS
> Sirius Corporation plc - control through freedom
> http://www.siriusit.co.uk
> t: +44 870 608 0063
> Sirius Labs: http://www.siriusit.co.uk/labs
> postgis-users mailing list
