[postgis-users] Why can't PostGIS ./configure find libgeos_c ??
kreshna_iceheart at yahoo.com
Tue Nov 17 04:19:57 PST 2009
Ah yes, almost forgot. I'm using PostGIS 1.4.0 and Geos 3.1.1. My linux version is CentOS release 4.2 (Final).
I followed the Geos installation from MapServer's Verbose Linux Installation (http://marwp.cla.umn.edu/gis/docs/verbose_install.html), and everything went well. I also ran postgis isntaller from /usr/local/postgresql-8.3.5/contrib/postgis-1.4.0.
What's wrong?
--- On Tue, 11/17/09, kreshna_iceheart at yahoo.com <kreshna_iceheart at yahoo.com> wrote:
> From: kreshna_iceheart at yahoo.com <kreshna_iceheart at yahoo.com>
> Subject: [postgis-users] Why can't PostGIS ./configure find libgeos_c ??
> To: postgis-users at postgis.refractions.net
> Date: Tuesday, November 17, 2009, 7:08 AM
> I'm compiling PostGIS with the
> following command:
> ./configure --with-pgconfig=/usr/local/pgsql/bin/pg_config
> --with-geosconfig=/usr/local/bin/geos-config
> Yet I keep getting this error message:
> configure: error: could not find libgeos_c - you may need
> to specify the directory of a geos-config file using
> --with-geosconfig
> The problem is: libgeos_c.so does indeed exist in the
> /usr/local/lib/. Also, geos-config points to the right
> direction. Here is the first four lines of geos-config:
> #!/bin/sh
> prefix=/usr/local
> exec_prefix=${prefix}
> libdir=/usr/local/lib
> What happens? What should I do? I have tried everything ad
> nauseam, yet the error message keeps showing up. Help!!!
> -Kresh
> postgis-users mailing list
