[postgis-users] C++ and Postgis
Pedro Doria Meunier
pdoria at netmadeira.com
Tue Nov 24 02:36:56 PST 2009
Maxime,
Thank for your answer. This is *useful* information indeed!.
IMHO, given a more complete example (like mentioning the #includes of
the necessary headers and perhaps showing how to deal with one or more
of the primitives (points, linestrings, etc) ) this information *should*
make part of the 5th chapter PostGIS Manual!
BR,
Pedro.
On 11/24/2009 08:58 AM, Maxime van Noppen wrote:
> Pedro Doria Meunier wrote:
>> How does one deal with Postgis geom fields in C++ ?
>> Google hasn't offered much help so far.
> Hi, I know you got a better answer to your problem but just in case it
> might help someone here is how I transfer data from postgis to libpq / C++ :
> pqxx::connection db("host=.... dbname=... user=...");
> pqxx::work xaction(db, "gis");
> const pqxx::result& res = xaction.exec("SELECT geom FROM sometable;");
> // by default, geom is in WKB
> std::istringstream istr(res[0].c_str());
> geos::geom::GeometryFactory factory;
> geos::io::WKBReader wkbr(factory);
> geos::geom::Geometry* geom = wkbr.readHEX(istr);
> // use geom.
> std::cout<< "geom is a "<< geom->getGeometryType()<< std::endl;
> delete geom;
