[postgis-users] Suggestion Needed
Luigi Castro Cardeles
luigi.cardeles at gmail.com
Tue Nov 24 08:47:53 PST 2009
to "bypass" the password, you can make the .pgpass file and fill that with
your connection params (hostname:port:database_name:user:password).
If you are using windows, the path is: C:\Users\<your user
name>\AppData\Roaming\postgresql\.pgpass
best regards
2009/11/24 mukesh karanwal <mukesh_karanwal at yahoo.com>
> Hey Everyone,
> I am trying to store raster data in Postgis/PostgrSQL using "*
> geotiff2pgrstaer.exe*". but evertime i get an error that "*when making
> connection to PostgreSQL: fe_sendauth: no password supplied*", though i am
> supplying all the information.
> The command i am giving is like:
> *C:\..> geotiff2pgraster -h localhost -p 5432 -d postgis -U postgres -P
> <mypassword> data.tif(strored at this location only) tablename*
> Kindly tell the remedy for the above problem and also is there any other
> way out to store raster data until now?
> Thanks in anticipation
> With Regards,
> Mukesh
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20091124/a9f4108a/attachment.html>
