[postgis-users] Suggestion Needed
mukesh karanwal
mukesh_karanwal at yahoo.com
Wed Nov 25 03:29:59 PST 2009
Hi..
thanks for the reply.
i did it but still it is showing the same error!
I actually want to store a Geotiff file in the databse, could you please tell, is there any other way to do this? or where am i doing mistake, if any?
Thanks
--- On Tue, 11/24/09, Luigi Castro Cardeles <luigi.cardeles at gmail.com> wrote:
From: Luigi Castro Cardeles <luigi.cardeles at gmail.com>
Subject: Re: [postgis-users] Suggestion Needed
To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
Date: Tuesday, November 24, 2009, 10:17 PM
to "bypass" the password, you can make the .pgpass file and fill that with your connection params (hostname:port:database_name:user:password).
If you are using windows, the path is: C:\Users\<your user name>\AppData\Roaming\postgresql\.pgpass
best regards
2009/11/24 mukesh karanwal <mukesh_karanwal at yahoo.com>
Hey Everyone,
I am trying to store raster data in Postgis/PostgrSQL using "geotiff2pgrstaer.exe". but evertime i get an error that "when making connection to PostgreSQL: fe_sendauth: no password supplied", though i am supplying all the information.
The command i am giving is like:
C:\..> geotiff2pgraster -h localhost -p 5432 -d postgis -U postgres -P <mypassword> data.tif(strored at this location only) tablename
Kindly tell the remedy for the above problem and also is there any other way out to store raster data until now?
Thanks in anticipation
With Regards,
Mukesh
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
-----Inline Attachment Follows-----
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20091125/5321f19a/attachment.html>
