[postgis-users] Install postgis on a different schema
P Kishor
punk.kish at gmail.com
Tue Nov 24 12:13:32 PST 2009
Leo,
Many thanks for your clear replies. One follow-up question --
On Tue, Nov 24, 2009 at 1:29 PM, Paragon Corporation <lr at pcorp.us> wrote:
> d. The notes above refer to setting the search_path and the session_path.
> Where is that done?
> You can do it in postgresql.conf or at the database level. The database
> level is better I think
> ALTER DATABASE mydb SET search_path = public, shared
> The above will have it set for good, except if you restore a db, you need to
> remember to rerun the above command.
In the above note, should I be setting the search_path to the
different project schemas as well, and not just 'public' and 'shared'?
So, if I have the following schemas in mydb, 'public', 'shared',
'project1', 'project2' then the above command really should be
ALTER DATABASE mydb SET search_path = public, shared, project1, project2;
And, if I add another schema, 'project3', a few months later, then I run
project2, project3;
Correct?
By the way, what is that search_path doing? What is it for? And, why
don't I have to set it if I have only a 'public' schema? Is that
because by default, a public schema doesn't need an explicit search
path?
Puneet.
