[postgis-users] Install postgis on a different schema
MarkW
mark.wimer at gmail.com
Tue Nov 24 14:03:10 PST 2009
On Tue, Nov 24, 2009 at 5:01 PM, P Kishor <punk.kish at gmail.com> wrote:
> On Tue, Nov 24, 2009 at 3:55 PM, P Kishor <punk.kish at gmail.com> wrote:
> > On Tue, Nov 24, 2009 at 2:56 PM, MarkW <mark.wimer at gmail.com> wrote:
> >> On Tue, Nov 24, 2009 at 3:13 PM, P Kishor <punk.kish at gmail.com> wrote:
> >>> Leo,
> >>> Many thanks for your clear replies. One follow-up question --
> >>> On Tue, Nov 24, 2009 at 1:29 PM, Paragon Corporation <lr at pcorp.us>
> wrote:
> >>> > d. The notes above refer to setting the search_path and the
> >>> > session_path.
> >>> > Where is that done?
> >>> > You can do it in postgresql.conf or at the database level. The
> database
> >>> > level is better I think
> >>> > ALTER DATABASE mydb SET search_path = public, shared
> >>> > The above will have it set for good, except if you restore a db, you
> >>> > need to
> >>> > remember to rerun the above command.
> >>> In the above note, should I be setting the search_path to the
> >>> different project schemas as well, and not just 'public' and 'shared'?
> >>> So, if I have the following schemas in mydb, 'public', 'shared',
> >>> 'project1', 'project2' then the above command really should be
> >>> ALTER DATABASE mydb SET search_path = public, shared, project1,
> project2;
> >>> And, if I add another schema, 'project3', a few months later, then I
> run
> >>> project2, project3;
> >>> Correct?
> >>> By the way, what is that search_path doing? What is it for? And, why
> >>> don't I have to set it if I have only a 'public' schema? Is that
> >>> because by default, a public schema doesn't need an explicit search
> >>> path?
> >>> Puneet.
> >> If I could add another question to this thread since it's related to the
> >> PostGIS schema. I am moving to this "Project1" schema approach in prep
> for
> >> an upgrade and to keep the data in separate schema in the future. If my
> >> Project1 schema is dumped/backed up, then put back/restored after an
> upgrade
> >> of PostgreSQL/PostGIS, what's the best way to restore information in the
> >> Geometry_Columns table; should that be saved, or should I be using a
> >> function to re-populate the Geometry_Columns table?
> > I am not sure what you are asking above. If you backup Project1
> > schema, then restore it in another db, the_geom columns will all come
> > back. After all, backup will back up all the tables in that schema,
> > and restore will restore them. A table is a table, doesn't matter what
> > kind of columns it holds.
> > Maybe I misunderstood your concern.
> Yeah, I am pretty sure I misunderstood your problem. Disregard my
> response, and let's wait for a more educated response. I am curious as
> well now.
> > Puneet Kishor http://www.punkish.org
> > Carbon Model http://carbonmodel.org
> > Charter Member, Open Source Geospatial Foundation http://www.osgeo.org
> > Science Commons Fellow, http://sciencecommons.org/about/whoweare/kishor
> > Nelson Institute, UW-Madison http://www.nelson.wisc.edu
> > Assertions are politics; backing up assertions with evidence is science
> > Sent from Madison, Wisconsin, United States
Thanks Puneet - sorry for the confusion. I was referring to the
"geometry_columns" table - I believe it's always in the public schema along
with postGIS functions and not in each schema; I wonder if I need to worry
about backing that up, or is this what one of the newer functions is for:
http://postgis.refractions.net/documentation/manual-1.4/Populate_Geometry_Columns.html
Mark
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20091124/f19d2e5e/attachment.html>
