[postgis-users] Install postgis on a different schema
P Kishor
punk.kish at gmail.com
Tue Nov 24 14:01:36 PST 2009
On Tue, Nov 24, 2009 at 3:55 PM, P Kishor <punk.kish at gmail.com> wrote:
> On Tue, Nov 24, 2009 at 2:56 PM, MarkW <mark.wimer at gmail.com> wrote:
>> On Tue, Nov 24, 2009 at 3:13 PM, P Kishor <punk.kish at gmail.com> wrote:
>>> Leo,
>>> Many thanks for your clear replies. One follow-up question --
>>> On Tue, Nov 24, 2009 at 1:29 PM, Paragon Corporation <lr at pcorp.us> wrote:
>>> > d. The notes above refer to setting the search_path and the
>>> > session_path.
>>> > Where is that done?
>>> > You can do it in postgresql.conf or at the database level. The database
>>> > level is better I think
>>> > ALTER DATABASE mydb SET search_path = public, shared
>>> > The above will have it set for good, except if you restore a db, you
>>> > need to
>>> > remember to rerun the above command.
>>> In the above note, should I be setting the search_path to the
>>> different project schemas as well, and not just 'public' and 'shared'?
>>> So, if I have the following schemas in mydb, 'public', 'shared',
>>> 'project1', 'project2' then the above command really should be
>>> ALTER DATABASE mydb SET search_path = public, shared, project1, project2;
>>> And, if I add another schema, 'project3', a few months later, then I run
>>> project2, project3;
>>> Correct?
>>> By the way, what is that search_path doing? What is it for? And, why
>>> don't I have to set it if I have only a 'public' schema? Is that
>>> because by default, a public schema doesn't need an explicit search
>>> path?
>>> Puneet.
>> If I could add another question to this thread since it's related to the
>> PostGIS schema. I am moving to this "Project1" schema approach in prep for
>> an upgrade and to keep the data in separate schema in the future. If my
>> Project1 schema is dumped/backed up, then put back/restored after an upgrade
>> of PostgreSQL/PostGIS, what's the best way to restore information in the
>> Geometry_Columns table; should that be saved, or should I be using a
>> function to re-populate the Geometry_Columns table?
> I am not sure what you are asking above. If you backup Project1
> schema, then restore it in another db, the_geom columns will all come
> back. After all, backup will back up all the tables in that schema,
> and restore will restore them. A table is a table, doesn't matter what
> kind of columns it holds.
> Maybe I misunderstood your concern.
Yeah, I am pretty sure I misunderstood your problem. Disregard my
response, and let's wait for a more educated response. I am curious as
well now.
> Puneet Kishor http://www.punkish.org
> Carbon Model http://carbonmodel.org
> Charter Member, Open Source Geospatial Foundation http://www.osgeo.org
> Science Commons Fellow, http://sciencecommons.org/about/whoweare/kishor
> Nelson Institute, UW-Madison http://www.nelson.wisc.edu
> Assertions are politics; backing up assertions with evidence is science
> Sent from Madison, Wisconsin, United States
