[postgis-users] Install postgis on a different schema
P Kishor
punk.kish at gmail.com
Tue Nov 24 13:55:12 PST 2009
On Tue, Nov 24, 2009 at 2:56 PM, MarkW <mark.wimer at gmail.com> wrote:
> On Tue, Nov 24, 2009 at 3:13 PM, P Kishor <punk.kish at gmail.com> wrote:
>> Leo,
>> Many thanks for your clear replies. One follow-up question --
>> On Tue, Nov 24, 2009 at 1:29 PM, Paragon Corporation <lr at pcorp.us> wrote:
>> > d. The notes above refer to setting the search_path and the
>> > session_path.
>> > Where is that done?
>> > You can do it in postgresql.conf or at the database level. The database
>> > level is better I think
>> > ALTER DATABASE mydb SET search_path = public, shared
>> > The above will have it set for good, except if you restore a db, you
>> > need to
>> > remember to rerun the above command.
>> In the above note, should I be setting the search_path to the
>> different project schemas as well, and not just 'public' and 'shared'?
>> So, if I have the following schemas in mydb, 'public', 'shared',
>> 'project1', 'project2' then the above command really should be
>> ALTER DATABASE mydb SET search_path = public, shared, project1, project2;
>> And, if I add another schema, 'project3', a few months later, then I run
>> project2, project3;
>> Correct?
>> By the way, what is that search_path doing? What is it for? And, why
>> don't I have to set it if I have only a 'public' schema? Is that
>> because by default, a public schema doesn't need an explicit search
>> path?
>> Puneet.
> If I could add another question to this thread since it's related to the
> PostGIS schema. I am moving to this "Project1" schema approach in prep for
> an upgrade and to keep the data in separate schema in the future. If my
> Project1 schema is dumped/backed up, then put back/restored after an upgrade
> of PostgreSQL/PostGIS, what's the best way to restore information in the
> Geometry_Columns table; should that be saved, or should I be using a
> function to re-populate the Geometry_Columns table?
I am not sure what you are asking above. If you backup Project1
schema, then restore it in another db, the_geom columns will all come
back. After all, backup will back up all the tables in that schema,
and restore will restore them. A table is a table, doesn't matter what
kind of columns it holds.
Maybe I misunderstood your concern.
> Mark
Puneet Kishor http://www.punkish.org
Carbon Model http://carbonmodel.org
Charter Member, Open Source Geospatial Foundation http://www.osgeo.org
Science Commons Fellow, http://sciencecommons.org/about/whoweare/kishor
Nelson Institute, UW-Madison http://www.nelson.wisc.edu
Assertions are politics; backing up assertions with evidence is science
Sent from Madison, Wisconsin, United States
