[postgis-users] point to multipoint
Mehmet Sirin
m.sirin07 at googlemail.com
Wed Nov 25 16:52:00 PST 2009
hi, is someone out there who can explain how to make several points to a
multipoint.. i tried st_union and st_collect but what comes out is a
multilinestring and geometrycollection(string(..)) respectively.
code with which the unwilling multilinestring happens:
select astext(st_union(c.geom_4326)) from (
select * from (select * from(
select *,buffer(geom_4326,0.01)as buff from gc_berechnet where
name='Neuer Graben' and
gemeinde='Osnabrück')a)b, zip_coordinates zc
where contains(buff,zc.geom) )c
what i want to do:
1.buffering a pointt (A) with a radius of 1km
2.take a look which other points lie in this buffer polygon
3.find out which point inside the buffer is nearest to the first point (A) i
buffered.
important for 3. : when having a multipoint i can easily use st_distance to
determine the closest point to point (A)
you can tell me how to create multipoint ? then i love you^^
leaving you kind regards
mehmet sirin c.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20091126/d32abc9a/attachment.html>
