[postgis-users] Compiling PostGIS 1.4.0 release on Solaris 10
Nathan Widmyer
lighthousej at gmail.com
Thu Nov 26 07:29:26 PST 2009
It's Solaris 10 8/07, the box is only about a year old.
I do get two types of test failures though...
1. I get differences in error message formats.
The tests expect an error message, "ERROR: parse error - invalid
geometry" but the tests return "ERROR: parse error - invalid geometry
at character 18"
I think the PGIS developers added "at character X" in a few error
messages too, not just parse errors.
Tests in error: regress, wkt, regress_ogc
Possible Fix: update the tests to expect the extra information
2. The endianness of WKB that is expected differs from the actual WKB
returned. I have converted each WKB to WKT on both and they match
exactly by their text representations.
Tests in error: sql-mm-compoundcurve, sql-mm-curvepoly
Possible Fix: have alternate expectation files for Solaris, compare
the WKT instead of WKB, or if there's a way, force PGIS to write WKB
in a particular endianness.
Thanks,
Nate
On Wed, Nov 25, 2009 at 2:21 PM, Paul Ramsey <pramsey at cleverelephant.ca> wrote:
> How old is your solaris? I just got my OpenSolaris VM back up and
> running, but it's very fresh indeed. I'll get some testing going on
> that.
> P
> On Wed, Nov 25, 2009 at 10:42 AM, Nathan Widmyer <lighthousej at gmail.com> wrote:
>> Ah, thank you for clearing that up.
>> I was going off of:
>> http://postgis.refractions.net/documentation/manual-1.4/ch02.html#id2531756
>> which, respectively,
>> Which is how I've always built software, test before install, so I
>> didn't question the directions.
>> I understand not conflicting with a running PostgreSQL, but is there a
>> socket-only connection style like MySQL can do to connect to just that
>> specific instance?
>> I figured the tests were writing to a temp postgis.sql somewhere so it
>> wouldn't require installing into PostgreSQL, and something like a sed
>> or shell command wasn't working quite right.
>> There is a shell command to call "pushd" (regress/Makefile.in), which
>> doesn't exist in my user compiling PostGIS that uses bourne shell by
>> default (not bourne again shell), so I didn't know if there were other
>> things being called that don't exist on Solaris.
>> I just ran make check and it failed 5 out of 42 tests, so I'll take a
>> closer look at it.
>> Thanks again for letting me know, and I'll definitely put that down as
>> the thing to do.
>> Nate
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
