[postgis-users] Compiling PostGIS 1.4.0 release on Solaris 10
Nathan Widmyer
lighthousej at gmail.com
Thu Nov 26 07:54:27 PST 2009
The machine has a system PostgreSQL 8.1 something but no PostGIS extensions.
The box also has Pg 8.4.0 with PostGIS 1.4.0 (GEOS 3.1.1) that I
compiled about six months ago. I thought the instance was turned off
for several reasons, but I see what you mean of a mixup in Pg
instances, I'll check that out.
Yes, it's a newer sun sparc box. I know what you mean about the
prevalence of x86. I posted to the list before about the endianness
before and got the surprising response that there's not any
established PostGIS build system, I was surprised considering how
robust the linux and windows installers are, with stackbuilder and
everything to make it incredibly easy. Postgres for sparc is just a
tarball, I have to run initdb by hand to get a database.
Thanks for the information about AsBinary though, good to know to make
the DB backup/dml more portable.
Nate
On Thu, Nov 26, 2009 at 10:33 AM, Paul Ramsey <pramsey at opengeo.org> wrote:
> On Thu, Nov 26, 2009 at 7:29 AM, Nathan Widmyer <lighthousej at gmail.com> wrote:
>> 1. I get differences in error message formats.
>> The tests expect an error message, "ERROR: parse error - invalid
>> geometry" but the tests return "ERROR: parse error - invalid geometry
>> at character 18"
>> I think the PGIS developers added "at character X" in a few error
>> messages too, not just parse errors.
>> Tests in error: regress, wkt, regress_ogc
>> Possible Fix: update the tests to expect the extra information
> That's extremely odd, any particular tarball should have tests and
> expectations that match the version. Are you sure you don't have an
> old PostGIS hanging around somewhere that doesn't match your test
> suite?
>> 2. The endianness of WKB that is expected differs from the actual WKB
>> returned. I have converted each WKB to WKT on both and they match
>> exactly by their text representations.
>> Tests in error: sql-mm-compoundcurve, sql-mm-curvepoly
>> Possible Fix: have alternate expectation files for Solaris, compare
>> the WKT instead of WKB, or if there's a way, force PGIS to write WKB
>> in a particular endianness.
> You're on an honest-to-god RiSC machine? nice. There's a second
> parameter to AsBinary that you can use to control endianness. I think
> we default to little endian, since that's so prevalent now, you if you
> put 'xdr' into the second parameter you'll get out big endian.
> P.
>> Thanks,
>> Nate
>> On Wed, Nov 25, 2009 at 2:21 PM, Paul Ramsey <pramsey at cleverelephant.ca> wrote:
>>> How old is your solaris? I just got my OpenSolaris VM back up and
>>> running, but it's very fresh indeed. I'll get some testing going on
>>> that.
>>> P
>>> On Wed, Nov 25, 2009 at 10:42 AM, Nathan Widmyer <lighthousej at gmail.com> wrote:
>>>> Ah, thank you for clearing that up.
>>>> I was going off of:
>>>> http://postgis.refractions.net/documentation/manual-1.4/ch02.html#id2531756
>>>> which, respectively,
>>>> Which is how I've always built software, test before install, so I
>>>> didn't question the directions.
>>>> I understand not conflicting with a running PostgreSQL, but is there a
>>>> socket-only connection style like MySQL can do to connect to just that
>>>> specific instance?
>>>> I figured the tests were writing to a temp postgis.sql somewhere so it
>>>> wouldn't require installing into PostgreSQL, and something like a sed
>>>> or shell command wasn't working quite right.
>>>> There is a shell command to call "pushd" (regress/Makefile.in), which
>>>> doesn't exist in my user compiling PostGIS that uses bourne shell by
>>>> default (not bourne again shell), so I didn't know if there were other
>>>> things being called that don't exist on Solaris.
>>>> I just ran make check and it failed 5 out of 42 tests, so I'll take a
>>>> closer look at it.
>>>> Thanks again for letting me know, and I'll definitely put that down as
>>>> the thing to do.
>>>> Nate
>>>> _______________________________________________
>>>> postgis-users mailing list
>>>> postgis-users at postgis.refractions.net
>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
