[postgis-users] Merging two overlapping polygons
Alexandre Dube
adube at mapgears.com
Thu Oct 1 09:04:02 PDT 2009
Kevin,
That's a wonderful idea. I just tested it and it worked.
Thanks a lot,
Alexandre
Kevin Neufeld wrote:
> If I understand correctly, why don't you just ST_Union as you are
> doing below, then wrap the results in ST_Dump to explode the MULTI
> result. Then you'll have your merged polygon where they overlap as
> well as any individual lone-ranger polygons.
> SELECT (ST_Dump(singlegeom)).geom
> FROM (
> SELECT ST_Multi(ST_Union(f.the_geom)) as singlegeom
> FROM mytable
> ) AS foo;
> -- Kevin
Alexandre Dubé
Mapgears
www.mapgears.com
