[postgis-users] Slow Postgres Query
Randall, Eric ERandall at eriecountygov.org
Fri Oct 2 10:20:27 PDT 2009
Hi there dassouki,
Right, no way that should take so long.  I created 60 point and 2000 line tables from addresses and road centerlines
to do a test.  The tables are called "sixtypoints" and "twothousandlines".  Then created a "linespoints" table to store point and nearest line ids:
create table linespoints (
point_id integer,
nearest_line_id integer );
Then created a function to insert the point and nearest line ids:
create or replace function insert_into_linespoints() returns integer as $$
	declare
        getrow cursor for select * from sixtypoints;
        point_row sixtypoints%rowtype;
        v_nearest_line_id integer;
        max_rows integer;
	  rowcount integer;
	begin
	  delete from  linespoints;
        select into max_rows count(*) from sixtypoints;
	  open getrow;
        rowcount := 0;
        while rowcount < max_rows LOOP   --of course, could have just said 60
        fetch getrow into point_row;
        rowcount := rowcount + 1;
        select into v_nearest_line_id
        twothousandlines.gid
        from  twothousandlines
        order by st_distance(twothousandlines.geom,point_row.geom)
        limit 1;
        insert into linespoints values (point_row.gid, v_nearest_line_id );
        end loop;
	  close getrow;
	  return(rowcount);
     end;
$$ language plpgsql
Then ran it:
select insert_into_linespoints()   --389ms
Then made lines from info in the three tables:
select st_makeline(sixtypoints.geom,st_line_interpolate_point(st_geometryn(twothousandlines.geom,1),st_line_locate_point(st_geometryn(twothousandlines.geom,1),sixtypoints.geom)))
from twothousandlines, sixtypoints, linespoints
where sixtypoints.gid = linespoints.point_id
and twothousandlines.gid = linespoints.nearest_line_id
--12ms
In retrospect, I probably would add a geometry column to the "linespoints" table and insert the line during the function rather than having the third step.  I didn't understand why you needed to "explode" to linestrings as you called it but I guess it has to do with your data.  The "order by st_distance() ... limit 1"  is what you needed mainly I think to give you each single nearest line.
Hopefully this is what you're trying to do.
Eric
Eric Randall
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net]On Behalf Of
dassouki
Sent: Thursday, October 01, 2009 11:38 AM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] Slow Postgres Query
Hey All,
As some of you know, I've been trying to connect a point from a point
table to the projection of that point on the nearest line for close to
forever now.
I've managed to get the code working for a small set of points and
lines; however, on a 60 node with 2,000 lines, the query is in its 11th
hour and still no sign of ending.
I posted a question including code on stack overflow
http://stackoverflow.com/questions/1504353/slow-postgres-query
I was wondering if anyone here has any idea on what I might be doing
wrong ? and if there is a way to make the code more efficient
cheers,
dassouki
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
