[postgis-users] Slow Postgres Query
Emilie Laffray emilie.laffray at gmail.com
Thu Oct 1 08:44:19 PDT 2009
2009/10/1 dassouki <dassouki at gmail.com>
> Hey All,
> As some of you know, I've been trying to connect a point from a point table
> to the projection of that point on the nearest line for close to forever
> now.
> I've managed to get the code working for a small set of points and lines;
> however, on a 60 node with 2,000 lines, the query is in its 11th hour and
> still no sign of ending.
> I posted a question including code on stack overflow
> http://stackoverflow.com/questions/1504353/slow-postgres-query
> I was wondering if anyone here has any idea on what I might be doing wrong
> ? and if there is a way to make the code more efficient
Hum, I am no expert but it looks like your 3000000 is way too high. I think
you need to tune your query to values that makes more sense in your current
srid.
I am using the same function on a table with a huge number of lines (read
several millions), and it works quite fast for me.
Emilie Laffray
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20091001/0dbb750e/attachment.html>
