[postgis-users] how to create holes in polygon
Pavel Iacovlev iacovlev.pavel at gmail.com
Mon Oct 5 05:05:01 PDT 2009
Join all your polygons into 1 multi-polygon.
Run ST_Difference between your area (a rectangle for the whole world I
guess) and the your multi-polygon. This should produce the expected
results.
On Mon, Oct 5, 2009 at 3:00 PM, Kevin Kempfer <postgis at kevinkempfer.de> wrote:
> Hi,
> I am trying to punch holes into a polygon - can someone tell me how to
> achieve this?
> I have a large database of polygon geometries.
> I am now trying to "invert" these polygons area to receive a big
> polygon, that covers everything that is *not* covered in my existing
> polygons.
> The result should be a polygon covering the whole world but with holes
> in the areas which are already covered by my source polygons.
> I successfully created a "positive" using geomunion() on all my geoms.
> Now I need to invert the result  to get a "negative". Hope I got the
> idea across...
> Thanks for any advice,
> Kevin
> postgis-users mailing list
http://iap.md, The future is open
