[postgis-users] Cut lines with polygon
Alexander Strunck
A.Strunck at gmx.net
Mon Oct 5 05:27:10 PDT 2009
Hello
i am really new to postgis and i try to cut lines with a polygon. the sql statement is
create table osm_line_in_dorfring2_5_10 as
SELECT b.way_id, b.geom,
Intersection ( g.geom, b.geom )
FROM stadtdorfbuffer2_5_10 AS g, osm_line AS b
WHERE IsEmpty ( Intersection ( g.geom, b.geom ) ) = FALSE;
but when i look at the result the lines are not cut by the polygon. the lines go a little bit over the borders of the polygon. Why is that?
the second problem ist when i want to do the same thing with two different polygon tables. i get the error
NOTICE: TopologyException: found non-noded intersection between 8.18405 48.9483, 8.18366 48.9481 and 8.18285 48.947, 8.18933 48.9551 8.18381 48.9482
ERROR: GEOS Intersection() threw an error!
********** Fehler **********
SQL Status:XX000
i tested the polygon tables with ST_IsValid and everything seems to be all right.
does someone have any suggestions?
thx in advance
alex
GRATIS für alle GMX-Mitglieder: Die maxdome Movie-FLAT!
Jetzt freischalten unter http://portal.gmx.net/de/go/maxdome01
