[postgis-users] find nearest point on line where distance to point not on line is minimum - or lets say drop a perpendicular on the nearest line through a given point
Marco Lechner - FOSSGIS e.V.
marco.lechner at fossgis.de
Fri Oct 16 04:54:54 PDT 2009
Hi Mehmet,
thank you. This seems to be much faster then my experiments combining
line_locate_point() and line_interpolate_point() in subselects. The main
problem is now, that i have a bunch of lines (not just one specific) in
a table and I want the point to be calculated on the nearest line. The
recent request takes about 1.2 seconds because I have to calculate the
distances to all lines first to identify the nearest line. Is there a
better way?
Recent request:
SELECT multiline_locate_point(line, point) AS Ppoint_on_line FROM
(SELECT distance(the_geom, pointfromtext('POINT(3440580 5350000)',
31467)) AS dist, pointfromtext('POINT(3440580 5350000)', 31467) AS
point, the_geom AS line FROM linetable ORDER BY dist LIMIT 1) as foo
Marco
Mehmet Sirin schrieb:
> hi, i think you're searching this:
> http://pgrouting.postlbs.org/wiki/LoadingtheCode4
> bye
> 2009/10/16 Marco Lechner - FOSSGIS e.V. <marco.lechner at fossgis.de
> <mailto:marco.lechner at fossgis.de>>
> hi,
> I try to find a way to solve this problem in postgis.
> I have a table with lines an coorindates of a point that needn't to be
> on a line. I try to find
> 1. the id of the line wich is nearest to the point
> 2. get the coordinates of the point on the line which is nearest to the
> point
> --------0---------
> X (point X not on line)
> 0 is the nearest Point to X on line and therefore the Point i'm
> searching for.
> Any hints?
> Marco
> FOSSGIS e.V.
> die unabhängige Hilfe bei freier GIS-Software und freien Geodaten
> www.fossgis.de <http://www.fossgis.de>
> postgis-users mailing list
> <mailto:postgis-users at postgis.refractions.net>
++++++++BITTE VORMERKEN++++++++
INTERGEO 2009: 22.09. - 24.09.2009
in Karlsruhe; Halle 1, Stand 1.417
FOSSGIS e.V.
www.fossgis.de
