[postgis-users] St_within problem
Bob Pawley
rjpawley at shaw.ca
Tue Oct 20 08:08:33 PDT 2009
The geometry comes up true for st_isvalid and yes the points are covering
the geometry and beyond.
I'm curious as to how I could retrieve the geometry in order to include them
in an e-mail.
As a shapefile perhaps??
Bob
----- Original Message -----
To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
Sent: Monday, October 19, 2009 9:55 AM
Subject: Re: [postgis-users] St_within problem
> Bob Pawley wrote:
>> Funny this does work when I include st_box2d as in -
>> st_within( graphics.point_grid.the_geom,
>> st_box2d(library.dgm_process.the_geom))
>> However, this will include points within the box yet outside of the
>> actual geometry.
> It's hard to help without some additionnal data. Did you check that your
> geometry is valid (ST_IsValid) ? Did you manually check that it actually
> contains points ?
> Maxime
> postgis-users mailing list
