[postgis-users] St_within problem
Michael Smedberg
Michael.Smedberg at redfin.com
Tue Oct 20 08:29:58 PDT 2009
You can use the astext function to get the WKT ("well known text".)
E.g. you could do something like:
SELECT astext(the_geom) FROM library.dgm_process
which would return a textual representation of the geometries.
ST_GeomFromText is the opposite of astext- it'll convert the text to a
geometry object.
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Bob
Pawley
Sent: Tuesday, October 20, 2009 8:09 AM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] St_within problem
The geometry comes up true for st_isvalid and yes the points are
covering
the geometry and beyond.
I'm curious as to how I could retrieve the geometry in order to include
them
in an e-mail.
As a shapefile perhaps??
Bob
----- Original Message -----
To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
Sent: Monday, October 19, 2009 9:55 AM
> Bob Pawley wrote:
>> Funny this does work when I include st_box2d as in -
>> st_within( graphics.point_grid.the_geom,
>> st_box2d(library.dgm_process.the_geom))
>> However, this will include points within the box yet outside of the
>> actual geometry.
> It's hard to help without some additionnal data. Did you check that
your
> geometry is valid (ST_IsValid) ? Did you manually check that it
actually
> contains points ?
> Maxime
> postgis-users mailing list
