[postgis-users] ST_UNION - Exception in LWGEOM2GEOS
Mehmet Sirin m.sirin07 at googlemail.com
Mon Oct 26 16:24:07 PDT 2009
I just tried to create a mutlilinestring out of a set of linestrings via
SELECT AsText( ST_UNION(linestring) )
FROM ways w, way_tags wt WHERE w.id=wt.way_id
AND wt.v='Dörnter Weg'
(it lies in Osnabrück, lower saxony)
but I'm getting this strange error:
HINWEIS: IllegalArgumentException: point array must contain 0 or >1 elements
FEHLER: Exception in LWGEOM2GEOS
********** Fehler **********
SQL Status:XX000
Replacing wt.v='Dörnter Weg' with wt.v='Some other Streets' it works
properly.
So it is because of this street 'Dörnter Weg' (i got a few other ones of
this kind in my database).
Anybody can tell me why these sort of ways leads to a problem?
thank you
kind regards
mehmet sirin
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20091027/f72e07e9/attachment.html>
