[postgis-users] How cutting out polygon
Daniel Grum
daniel.grum at unibw.de
Tue Sep 1 10:04:05 PDT 2009
Pavel Iacovlev schrieb:
> You should translate the error message by the way if you want to get answers :)
> I think the problem is that your select returns multiple
> rows(geometries) but update expect 1 row. Try putting a
> ST_COLLECT/ST_UNION in your query.
> UPDATE fog_of_war
> SET the_geom = ( SELECT
> ST_Union(ST_Intersection(grenze_by.the_geom,ST_Expand(holzfaeller.the_geom,
> 5000)))
> FROM public.grenze_by grenze_by,
> public.holzfaeller holzfaeller WHERE
> grenze_by.the_geom && ST_Expand(holzfaeller.the_geom, 5000));
> 2009/9/1 Daniel Grum <daniel.grum at unibw.de>:
>> Hi.
>> How I can cut 4 or more differnt polygon geometries out of one big
>> geomtry[MULTIPOLYGON].
>> I have one polygon (saved in the schema.tabel.column:
>> public.fog_of_war.the_geom)
>> and from this I want to cut out the squares, that I create with:
>> SELECT ST_Intersection(grenze_by.the_geom,ST_Expand(holzfaeller.the_geom,
>> 5000))
>> FROM public.grenze_by grenze_by, public.holzfaeller holzfaeller WHERE
>> I don't want to save this cut out information in an extra table, I only want
>> to get a fog_of_war layer.
>> And You only can see what is behind this Layer(than you see the map and
>> bulidings) where the layer was cut out.
>> Can I solve this problem with UPDATE like this:
>> UPDATE fog_of_war
>> ST_Intersection(grenze_by.the_geom,ST_Expand(holzfaeller.the_geom, 5000))
>> I ask because I get the message: "FEHLER: als Ausdruck verwendete
>> Unteranfrage ergab mehr als eine Zeile"
>> Thanks in advance.
>> --Daniel
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
I have edited my SQL
The problem now is, that only the first row will be regarded in this:
UPDATE fog_of_war
SET the_geom = ST_BuildArea(St_Collect(grenze_by.the_geom,
ST_Expand(holzfaeller.the_geom, 3000)))
FROM public.grenze_by grenze_by, public.holzfaeller holzfaeller;
How I can regard all rows of the table in a UPDATE query --> because
ST_Union or ST_Collect don't work in a UPDATE query
--Daniel
