[postgis-users] How cutting out polygon
Daniel Grum daniel.grum at unibw.de
Tue Sep 1 10:20:49 PDT 2009
Daniel Grum schrieb:
> Pavel Iacovlev schrieb:
>> You should translate the error message by the way if you want to get
>> answers :)
>> I think the problem is that your select returns multiple
>> rows(geometries) but update expect 1 row. Try putting a
>> ST_COLLECT/ST_UNION in your query.
>> UPDATE fog_of_war
>> SET the_geom = (    SELECT
>> ST_Union(ST_Intersection(grenze_by.the_geom,ST_Expand(holzfaeller.the_geom,
>> 5000)))
>>                               FROM public.grenze_by grenze_by,
>> public.holzfaeller holzfaeller                               WHERE
>> grenze_by.the_geom && ST_Expand(holzfaeller.the_geom, 5000));
>> 2009/9/1 Daniel Grum <daniel.grum at unibw.de>:
>>> Hi.
>>> How I can cut 4 or more differnt polygon geometries out of one big
>>> geomtry[MULTIPOLYGON].
>>> I have one polygon (saved in the schema.tabel.column:
>>>  public.fog_of_war.the_geom)
>>> and from this I want to cut out  the squares, that I create with:
>>> SELECT
>>> 5000))
>>> FROM public.grenze_by grenze_by, public.holzfaeller holzfaeller WHERE
>>> I don't want to save this cut out information in an extra table, I
>>> only want
>>> to get a fog_of_war layer.
>>> And You only can see what is behind this Layer(than you see the map and
>>> bulidings) where the layer was cut out.
>>> Can I solve this problem with UPDATE like this:
>>> UPDATE fog_of_war
>>> 5000))
>>> I ask because I get the message: "FEHLER:  als Ausdruck verwendete
>>> Unteranfrage ergab mehr als eine Zeile"
>>> Thanks in advance.
>>> --Daniel
>>> postgis-users mailing list
>>> postgis-users at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
> I have edited my SQL
> The problem now is, that only the first row  will be regarded in this:
> UPDATE fog_of_war
> SET the_geom = ST_BuildArea(St_Collect(grenze_by.the_geom,
> ST_Expand(holzfaeller.the_geom, 3000)))
> FROM public.grenze_by grenze_by, public.holzfaeller holzfaeller;
> How I can regard all rows of the table in a UPDATE query --> because
> ST_Union or ST_Collect don't work in a UPDATE query
> --Daniel
And why only the last cut out was done, if I work with this repeatedly???:
UPDATE fog_of_war
UPDATE fog_of_war
ST_Expand(steinbruch.the_geom, 3000)))
FROM public.grenze_by grenze_by, public.steinbruch steinbruch;
UPDATE fog_of_war
ST_Expand(erzmine.the_geom, 3000)))
FROM public.grenze_by grenze_by, public.erzmine erzmine;
Is this a problem in using the function ST_BuildArea in UPDATE the
table: fog_of_war ???
--Daniel
