[postgis-users] User defined functions
Mike Toews
mwtoews at sfu.ca
Sun Sep 6 14:59:51 PDT 2009
You need to make a common trigger procedure in (for example) PL/pgSQL
that does the update on column X (i.e., NEW.X). See:
http://www.postgresql.org/docs/current/interactive/plpgsql-trigger.html
Then you can turn this common trigger procedure onto 1 or more tables
that have a column "X" that require similar desired actions from the
procedure. See:
http://www.postgresql.org/docs/current/interactive/triggers.html
If you use pgAdmin III, it has a great GUI for setting these up.
-Mike
Bob Pawley wrote:
> Hi
> I am attempting to understand user defined functions.
> I am in need of a common function that will update a column in table
> X when a trigger on table Y or table Z is triggered.
> Is the user defined function the way to go?... or would it be better
> to use a fourth table to trigger a common function?
> Bob
