[postgis-users] Points and lines
Mark Cave-Ayland
mark.cave-ayland at siriusit.co.uk
Tue Sep 8 02:17:58 PDT 2009
Tuomas Ruohonen wrote:
> What is wrong in my function, it doesnt stop or should it take so
> loooong... ? Minutes... Trying to insert to lines in table
> CREATE OR REPLACE FUNCTION make_point() RETURNS TRIGGER AS $start_point$
> BEGIN
> UPDATE positionreports SET the_geom = SetSRID(st_makepoint
> ("longitude","latitude"), 4326);
> RETURN NULL; -- result is ignored since this is an AFTER trigger
> END;
> $start_point$ LANGUAGE plpgsql;
> CREATE TRIGGER start_point
> AFTER INSERT OR UPDATE ON positionreports
> FOR EACH ROW EXECUTE PROCEDURE make_point();
Look carefully at your stored procedure - you're updating the contents
of the entire table every time someone modifies a single row.
Take a look at the documentation here:
http://www.postgresql.org/docs/8.4/interactive/plpgsql-trigger.html. You
should be using the NEW and OLD pseudotypes to change to contents of a
single row.
HTH,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
Sirius Labs: http://www.siriusit.co.uk/labs
