[postgis-users] Points and lines
Tuomas Ruohonen illurt at hotmail.com
Tue Sep 8 03:16:35 PDT 2009
Lets think that i am inserting only rows to table, not updating any data.
These NEW and OLD pseudos are still helping me ?
Br.
Tuomas
> Date: Tue, 8 Sep 2009 10:17:58 +0100
> From: mark.cave-ayland at siriusit.co.uk
> To: postgis-users at postgis.refractions.net
> Subject: Re: [postgis-users] Points and lines
> Tuomas Ruohonen wrote:
> > What is wrong in my function, it doesnt stop or should it take so
> > loooong... ? Minutes... Trying to insert to lines in table
> > CREATE OR REPLACE FUNCTION make_point() RETURNS TRIGGER AS $start_point$
> >     BEGIN
> >       UPDATE positionreports SET the_geom = SetSRID(st_makepoint
> >     ("longitude","latitude"), 4326);
> >         RETURN NULL; -- result is ignored since this is an AFTER trigger
> >     END;
> > $start_point$ LANGUAGE plpgsql;
> > CREATE TRIGGER start_point
> > AFTER INSERT OR UPDATE ON positionreports
> >     FOR EACH ROW EXECUTE PROCEDURE make_point();
> Look carefully at your stored procedure - you're updating the contents
> of the entire table every time someone modifies a single row.
> Take a look at the documentation here:
> http://www.postgresql.org/docs/8.4/interactive/plpgsql-trigger.html. You
> should be using the NEW and OLD pseudotypes to change to contents of a
> single row.
> HTH,
> Mark.
> Mark Cave-Ayland - Senior Technical Architect
> PostgreSQL - PostGIS
> Sirius Corporation plc - control through freedom
> http://www.siriusit.co.uk
> t: +44 870 608 0063
> Sirius Labs: http://www.siriusit.co.uk/labs
> postgis-users mailing list
_________________________________________________________________
Jaa muistosi verkossa haluamiesi henkilöiden kanssa.
http://www.microsoft.com/finland/windows/windowslive/products/photos-share.aspx?tab=1
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090908/9c59abea/attachment.html>
