[postgis-users] postgis.sql
Mark Cave-Ayland
mark.cave-ayland at siriusit.co.uk
Thu Sep 10 02:34:48 PDT 2009
Mark Vantzelfde wrote:
> BEGIN
> psql:postgis.sql:53: NOTICE: type "spheroid" is not yet defined
> DETAIL: Creating a shell type definition.
> psql:postgis.sql:53: ERROR: could not load library
> "/opt/PostgreSQL/8.4/lib/postgresql/postgis-1.4.so
> <http://postgis-1.4.so>": libgeos_c.so.1: cannot open shared object
> file: No such file or directory
> psql:postgis.sql:59: ERROR: current transaction is aborted, commands
> ignored until end of transaction block
Remember that the various .so libraries need to be visible to the server
at runtime, not just at build time. So you can either tweak your
PostgreSQL startup script to include a LD_LIBRARY_PATH=/usr/local/lib
declaration (assuming you used the defaults when you built GEOS/PROJ.4),
or tweak /etc/ld.so.conf with the relevant locations and then re-run
ldconfig.
HTH,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
Sirius Labs: http://www.siriusit.co.uk/labs
