[postgis-users] Import ESRI shapefiles into PostGIS
Ben Madin
ben at remoteinformation.com.au
Thu Sep 10 18:42:40 PDT 2009
G'day,
As a start (and as noted in your previous post), the shp2pgsql program
writes a SQL file which you then need to import into postgres - so it
is a two stage process - but it is well covered in the manual, so it
sounds like something is going wrong.
Maybe you could include a copy of what you have done, and what output
happened when you tried it. Also, are you on windows or *nix? What
versions of the software are you using? And what projection do you
want the data to be in?
cheers
Ben
On 11/09/2009, at 4:25 , Cort D wrote:
> Please can somebody tell me how to import my ESRI shapefiles and
> attribute
> tables into PostGIS.
> I have been trying to use the shp2pgsql function but its either i am
> not
> using it correctly or its just not working for me.
> Please can someone out there help me. I am very new to PostGIS
> application.
Ben Madin
REMOTE INFORMATION
t : +61 8 9192 5455
f : +61 8 9192 5535
m : 0448 887 220
Broome WA 6725
Out here, it pays to know...
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090911/ab6e4999/attachment.html>
