[postgis-users] PostgreSQL 8.3.8 and 8.4.1 out
Paragon Corporation
lr at pcorp.us
Sun Sep 13 17:40:56 PDT 2009
If you are running 8.3.5+
Just replace the binaries for PostgreSQL (so if you compiled yourself, I
guess that would be a recompile for you and install). No change at all
needed for the PostGIS part of it.
For Linux -- if you are using the yum repository its just Yum upgrade
For windows -- just download the PostgreSQL 8.3.8 and install ontop of your
PostgreSQL 8.3.x (if you are running 8.3.5+) - again nothing to do for
Hope that helps,
Regina
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of P Kishor
Sent: Sunday, September 13, 2009 6:24 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] PostgreSQL 8.3.8 and 8.4.1 out
On Sun, Sep 13, 2009 at 12:31 AM, Paragon Corporation <lr at pcorp.us> wrote:
> Just in case some people don't know.
> PostgreSQL 8.3.8 and 8.4.1 came out last week and while they are
> mostly security bug fixes, they do include some speed enhancements.
I have PostGIS 1.4/PostGres 8.4. What is the recommended way of upgrading
this combo? Do I have to recompile PostGres and then PostGIS again? Do I
have to rebuild my databases? Is there a tutorial/knowledgebase article on
the various upgrade paths possible?
> For 8.4.1 -- "improve performance when processing toasted values in
> index scans"
> Which fixes the below bug.
> http://postgis.refractions.net/pipermail/postgis-devel/2009-August/006
> 659.ht
> ml
> (though I guess it wasn't backported to 8.3 since I don't see it
> listed in
> 8.3.8 release notes)
> http://www.postgresql.org/docs/8.4/static/release-8-4-1.html
> For both 8.3.8, 8.4.1 -- has for "Fix Windows shared-memory allocation "
> This bug led to the often-reported "could not reattach to shared memory"
> http://www.postgresql.org/docs/8.3/static/release-8-3-8.html
> Hope that helps,
> Regina
> postgis-users mailing list
Puneet Kishor http://www.punkish.org
Carbon Model http://carbonmodel.org
Charter Member, Open Source Geospatial Foundation http://www.osgeo.org
Science Commons Fellow, http://sciencecommons.org/about/whoweare/kishor
Nelson Institute, UW-Madison http://www.nelson.wisc.edu
Assertions are politics; backing up assertions with evidence is science
