[postgis-users] shp2pgsql encoding problem - Thai Language
Paul Hastings
paul.hastings at gmail.com
Tue Sep 15 21:01:27 PDT 2009
Ben Madin wrote:
> can tell, the encoding is ISO-8559-11 (not an official encoding, but
> similar to other latin/non-latin encodings)
iso-8859-11 *is* an "official" encoding but depending on where you got the data,
it's more likely to be windows-874 or TIS-620 codepages. or could even be mac
thai (though not likely, nobody i know *here* uses a mac for any GIS work but
you never know). i can't actually recall there being any difference between
these codepages but MS sure likes to do supersets, so better double check.
> Is this a hopeless case - do I need to (can I?) edit the .dbf file to
> remove the columns with the Thai encoding and then type them all back
> in!? Is there another way?
i normally pull out non-unicode text into a file, convert that to utf-8, import
& update the real data. i also recall qgis being able to handle this too.
just for thai:
http://www.lyndonhill.com/Projects/thaiconv.html
or better yet:
http://www.melody-soft.com/html/unifier.html
best $20 you'll ever spend...
